Old 11-30-2007, 03:21 PM   #10
blackONblack
Originally Posted by blkboxster
So can you give me the new tire sizes for the front and rear, what you said just confused me.
For your rear rim being so wide, so smallest width you can use that will stretch and fit is 265/35. If you increase the width (275-285) then you will have to decrese the sidewall hieght (275/30 or 285/25). But as I stated before if you go much wider in the rear you will have fender/strut rub issues. Your front rims are the same width as stock rims so there is no difference there. 225/40 front will fit fine and fill out the wheel well without spacers.
Front 225/40
Rear 265/35 or 275/30.
blackONblack is offline   Reply With Quote
