Originally Posted by Tool Pants
For a normal brake fluid change you do not need a PST2 if you have traction control or PSM. You do need it however if you are changing the fluid because those components have been replaced.
I did my research on this particular relationship and found similar statements. Unless one is also replacing master cylinder or other major component thank you for your confirmation. I am back to saving $150.00!
