Thread: Brake Fluid
Old 11-29-2007, 09:24 AM   #6
EE3racing
Guest
Posts: n/a
Originally Posted by Tool Pants
For a normal brake fluid change you do not need a PST2 if you have traction control or PSM. You do need it however if you are changing the fluid because those components have been replaced.
The manuals also say you need to hold down the clutch pedal when bleeding the clutch. You don't need to do this unless you have just replaced the master cylinder.
Can you elaborate on how you do bleed the clutch then TP? I am doing this soon and need all assistence.
