Thread: Brake Fluid
Old 11-29-2007, 09:32 AM   #1
bmussatti
Guest
Posts: n/a
Originally Posted by Tool Pants
For a normal brake fluid change you do not need a PST2 if you have traction control or PSM. You do need it however if you are changing the fluid because those components have been replaced.
The manuals also say you need to hold down the clutch pedal when bleeding the clutch. You don't need to do this unless you have just replaced the master cylinder.
Tool Pants, does this hold true for the 987 too? I thought you needed the PST2 for the 987 Boxster.
