Originally Posted by Allen K. Littlefield
Here are two pics of where I had to grind about 1/16" off in order to get the plate to fit flat on the top of the tower. Not a lot and I imagine each car is slightly a bit different. I will assemble the bar to the brackets and try to get that in place and report back my findings. Remember, it is me who is installing this and if anything can possibly go wrong, IT WILL ! ! ! :ah:
More this afternoon after the paint dries and the bar is installed. Thanks for all the advice.
AKL
What tool did you use for the grinding? My brackets are not fitting correctly either, the middle hole is not clearing the small screw.
