Old 11-25-2007, 03:14 PM   #1
jbox53
schnell alum shift linkage replacement
I did some digging. According to **************************************** the cable should slide into the linkage adapter. I suspect a quality issue with the steel adapter since I can see roughly cut edges on the mouth and allen-keyed holes. They are sending me a replacement part. Hopefully the replacement will accomodate the OEM linkage.
Has anyone installed the Schnell factory plastic linkage replacement (the$89 part)? I bought it and it looks like you have to cut the threaded portion of the linkage cable to make it work. I'm not crazy about doing that. Any thoughts?
jbox53 is offline   Reply With Quote
