Old 11-24-2007, 10:17 AM   #4
Tool Pants
Too late for you. http://www.renntech.org/forums/index.php?showtopic=6675 I also had problems with the rubber hose from the tank to the metal tube in the engine compartment. I got the clamp off but the hose was "glued" to the tube and I could not pull the hose off. But later we all learned it is better to do this from the top.
As for the coolant color, Porsche started using the pink stuff when the 987 came out. Then after a while the parts department only sold pink.
Tool Pants is offline   Reply With Quote
