Old 11-24-2007, 07:27 AM   #10
Franco
Franco's Avatar
Hi, Now I'm confused,
When a leaking RMS isn't fixed it could lead to an IMS failure right!!! and the culprit would be the RMS bearing gone bad and causing the IMS ( SHAFT) to spin off center causing the total engine meltdown or maybe the RMS oil leak was only from the 3 bolts holding the bearing housing in place and not cause any IMS failure at all.
Did i get this right or does the RMS seal and bearing have nothing to do with the IMS shaft failure, meaning that it fails on its own due to a bad design, what I'm trying to say is the IMS, the shaft being spun in place by the RMS bearing or are they not related at all and in different places in the engine.
I need another coffee
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
