Originally Posted by rick3000
According what I have read, the bar can be 3/4" or 1" thick. The bar should be 24" long with 22 1/4" between the two 3/8" holes. The end 2" of each side should be shaved down until flat. What we do not know is the length of the 3/8" bolts.
Hope this helps
To fabricate the bar is a joke, i used a 3/4 diameter aluminum bar, used a file to make 2 flats at each end to facilitate drilling 7/16 holes where the 3/8" diameter X 2" long screws and lock washers need to sit (on a flat surface), then i removed the existing metric screws on the triangular plate and installed the bar over it.
