Old 11-20-2007, 03:17 PM   #11
Franco
Franco's Avatar
Originally Posted by rick3000
According what I have read, the bar can be 3/4" or 1" thick. The bar should be 24" long with 22 1/4" between the two 3/8" holes. The end 2" of each side should be shaved down until flat. What we do not know is the length of the 3/8" bolts.
Hope this helps
To fabricate the bar is a joke, i used a 3/4 diameter aluminum bar, used a file to make 2 flats at each end to facilitate drilling 7/16 holes where the 3/8" diameter X 2" long screws and lock washers need to sit (on a flat surface), then i removed the existing metric screws on the triangular plate and installed the bar over it.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
