Old 11-20-2007, 07:45 AM   #20
arenared
Originally Posted by insite
i was referring to the rears. since the rears are the same diameter, with the same diameter pistons, ...
i'll see if i can find them.
Thanks, insite!
I looked up the rears, and the base is 292mm vs. 299mm with the S. So, there is some small difference. I was thinking it was more like 20mm like the front. My bad.
There are some very nice gains to be had with shifting the brake bias to the rear. The trick is finding pads with different mu friction but with similar temperature curves. Messing around with different pads to change the brake bias, there is a very noticeable difference in Gs.
arenared is offline   Reply With Quote
