I click 2 times but since I have a 1997 it does not matter.
To rule out the cap it needs to be pressure tested. In California every 2 years us older car owners have to do a smog inspection, and as part of that inspection the cap is pressure tested on the smog machine. Don't know what is done in other states.
So, I would rule out the cap so you could look elsewhere. If it is pressure tested in your state and the dealer that did the recall is near and the dealer has a smog machine, then maybe the dealer will test it as a favor.
If you can rule out the cap then report back.
