Originally Posted by rick3000
I do not understand your question, it is a little unclear.
From my understanding of what you are saying the top is operating perfectly.
You should have to hold down the top button the entire time the top is opening or closing. Then when the top dash light goes out you release the button.
If you continue to press the button the top will do the reverse of what it just did. So if you never release the top button, then it will open then close, then open, etc.
Hope his Helps!
Sorry if my message was garbled. When your light goes out, mine doesn’t. Further, when your light goes out and your finger is on the button, the motor is effectively aoutmattically turned off even if your finger is still on the button. Mine isn’t turned off.
As long as my finger is on the button, the motor will groan away as it jams up against either the windshield header or, into the open position, it would keep running till the top transmissions mechanisms were mangled (I let go of the button as soon as the clamshell shuts).
Hope that clarifies,
Thanks PK
