The ratio is calculated by the following formula:
, where- b = cylinder bore (diameter)
- s = piston stroke length
- Vc = volume of the combustion chamber (including head gasket). This is the minimum volume of the space into which the fuel and air is compressed, prior to ignition. Because of the complex shape of this space, it usually is measured directly rather than calculated.
Ahh...I just couldn't resist that.
Yes, Blinkwatt-you are correct. Higher compression-more HP. Here is the Wikipedia link for anyone who is just dying to know all about compression ratios....
http://en.wikipedia.org/wiki/Compression_ratio
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
