Old 11-04-2007, 11:55 AM   #17
mightysquirrel
Saving up and down wear is absurd. The top mechanicals are really good in these cars. So good that in the new boxster you can run the operation while to car is moving up to 30mph.
Any good top installer will tell you the best thing you can do for a top is keep it under tension. There are a variety of materials in the top that all respond to the environment differently and if you leave it down your top will deform in time.
The only time you should leave the top down is when you're driving or when you have the hard top on for winter. This will also keep dust and debris from building up in every crack and crevice in the interior when the car is not in use.
I don't care how clean you garage is, there's dust, just like in your house. Keep the top up.
M
mightysquirrel is offline   Reply With Quote
