Old 11-01-2007, 10:19 PM   #2
Tool Pants
You car is 4 digits off from the sticker I posted, from a local Boxster. Must have gone down the assembly line together. Both were made in November 1996.
As far as I have been able to determine cars made prior to January 1997 did not have the outside temp sensor in the front grill. We also have a local December 1996 that did not have the sensor. My January 1997 has the sensor and I do not have factory OBC.
A few years ago I retrofitted the sensor on the December car.
On your car if you had the OBC turned on all you will see is - - - three dashes as you do not have the sensor. You just have a rubber plug where the sensor would be.
Tool Pants is offline   Reply With Quote
