Old 10-31-2007, 12:07 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
2 reasons i can think of are 1. if your car was in an accident which damaged the chasis slightly which caused the caster to change on a wheel, since you have caster adjustment, you can now correct that... For instance, you pull into a parking spot on the street and you bump your front wheel on the curb as you rolled into the parking spot, that can bend your toe link arm and or throw off your caster.
2. You have a specific setting you'd like to achieve and you'd like to get your caster further back to obtain the camber you desire... adjustments in caster can give you more negative camber.
and maybe a 3rd reason why they are made as adjustibles.... the plant which they are made only makes adjustibles out of stock piles of different lengths of metal rods and they dont have to CNC machine a part to exact spec... probably easier to machine a bolt head to the end of a rod of steel and tap in some threads. Probably all cost related.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
