Old 10-29-2007, 07:58 PM   #10
Strawfordt
Recalibration????
Originally Posted by bmwm750
I have the opposite problem, which only occurred since I swapped clusters for a 996 cluster. Mine consistently reads optimistic, which I have concluded I need to go through the calibration process and that should cure my situation.
In yours, I would first pull out the sender, look at it, clean it, test the voltage it puts out, and see if that doesn't help. If the sender appears to be working properly, you may need a recalibration.
Patrick
Okay, that is interesting. How does one perform a recalibration of the fuel gauge?
I might just go for this one.
Tom
Windsor, Ontario Canada -- Silver 98 Boxster with black interior 90k kms -- Weekend toy, summers only
Strawfordt is offline   Reply With Quote
