Paint Fix
This is gutsy, but it has worked for me.
Lightly color sand the area with 2000 grit and water.
Rubout with a light liquid rubbing compound using your obital.
Then seal and wax with your obital.
You should see positive results as you rubout and then use step 3.
Process can be repeated ... remember to use light pressure during sanding, plenty of water and sand only in one direction.
Good luck ... let me know the result.
