Originally Posted by bmwm750
I also noticed that my interior microswitch on the driver side is behaving erratically as sometimes it will lower the window before I open the door, sometimes it won't.
Patrick
That sounds completely normal to me. The window is supposed to lower slightly when you pull up on the door handle and then pause, the window goes down a few millimeters so it doesn't catch the top. That is designed that way to create a tight seal so no rain gets inside the top between the window. If it's doing it only sometimes, your more than likely just opening the door to fast and not allowing the window to lower itself before you pull the door handle open all the way.
