Joe,
That is SO weird ! Mine car did that on the way home today. This is the third time it has happened, always on initial start up, and only when it is cold out.
I pulled over at the gas station, checked the level and it was fine. I did the same the prior two times it happened and the coolant was at the proper level as well. I attribute it to the cold weather. Also, when I turn the car off and back on the light never comes back. I would think as long as the level is ok and the light doesn't come back on it should be ok. I agree that I think it is ok to top off with distilled water if necessary...
Nick
