Old 10-24-2007, 01:23 PM   #3
ChipH
I took it to a Porsche dealer who did the installation. Very professional job, with the ipod connection cable, the usb cable and the aux input box all are located in the glovebox via a drilled hole in the box with a custom rubber grommet that seals each wire individually.
I have not tested the aux input yet. Having a CDR-24, you do not get the advantage of the nav screen showing you the selections, artists, playlists, etc. You basically get a disc selection 1 through 6 and the track numbers which go up to 99 and roll-over. You can select albums, playlists and artists with disc selection numbers 1, 2 and 3, but it is very difficult to figure out.
Personally I have a 60GB ipod with 32GB of music on the drive without playlists and I let it shuffle from the library. You do have the ability to press the scan button on the radio and it will scan the shuffling which I like to use as well.
No issues with the install and my limited use of the unit. The sound is AWSOME since it is a direct connection to the radio/bose amplifier. I will never use the single cd player again.
Selection is easy, press the cd button once and get CDS (single), press again and the display shows CDC and then the display shows 1 through 6 above the buttons starting from the left and then the track information above that.
The CDR-24 does not support the song titles on the radio 1 line text screen and the tachometer like the fm radio does via certain broadcasting stations.
All in all, the best upgrade I have added to my 2005 boxster to date. I love not being limited to a single cd for music. I also highly recommend the surround high mode for the bose with the ipod. It's an amazing virtual "digital" sound.
As far as where to install in your area, I would call the local Porsche dealers in your area and see if they have any experience with the denison products. That's what I did, called the two here in San Diego close to me and asked how I get an ipod connection in my boxster to start the process.
Lastly, I am told you need the latest firmware for the CDR-24 to operate correctly. 2.02 I believe. My unit came from the dealer and their distributor (bumperplugs.com) I believe with the correct version. The tech said they are a piece of cake to install and has done several. They charged me 475.00 US for the unit, and 375.00 to install. Less than the cost to install a CVD-changer !!
Good luck. Let me know if I can answer anyhting else. Figure this weekend I might hook a portable dvd player for a sound check via the two RCA jacks to see how the aux input works. Next step if it works is to add a portable sirius unit with an internal antenna and connect it to the aux input via a "rca to mini din adapter" and throw that in the glove box as well !!
ChipH is offline   Reply With Quote
