			I"ve found the best thing that helps is the rubberized electrical tape.  Not the thin "standard" stuff but the thick, stretchy, rubberized stuff.  Its black, so it blends in and is quite thick.  I put a few pieces on all 3 corners of each rollbar insert, nice and tight and no rattles.  As for the center windstop, you can replace the clips for about $2 each at your dealer which makes for a MUCH tighter fit, especially for those of you who have 10 year old cars.  If that's not enough, put a small piece of the tape between the piece rollbar mount and where the clip locks to tighten up the fit.  Mine are completely silent and I do not worry at all about mine blowing out.
 Patrick
