Old 10-21-2007, 07:48 PM   #4
pk2
Originally Posted by tholyoak
If you just want an injector controller:
http://www.splitsec.com/products/aic1/aic1ds.htm
But if it were me I would use an SMT6.
Todd
Hey Todd ..again,
I checked out the SMT6. Looks like it takes over your whole F.I. system with the extra injector just hold over. Do you think it’s overkill? TCP was pretty adamant that there controller not be used with any sort of other tweaks to the F.I controller.(I suppose with a Holistic setup like the SMT6, everything would balance out in one program)
I’m in So. Cal and emission are tough, TPC’s set up presumably will pass the sniff test and the visual… if the guy doesn’t look (their out there and sort of documented) or if he’s kinda clueless. Ya think SMT6 would be clean enough to pass the sniffer?
Have you used one? I’m not adverse to learning new software (can pick it up pretty well) but for a one shot deal, how complex is it going to be to take advantage of whatever improvements this might have over the relatively simple (looking) Split Second program.
Anyway, your thoughts are appreciated and valued.
Thanks again, PK
P.S. This things all plumbed except for the secondary injector controller and the blower is not on the belt (not turning). Runs rough, almost like a dead miss. Should it run ok under these circumstances or should I be looking for vacuum leak or somthing?
pk2 is offline   Reply With Quote
