Originally Posted by Ofishbein
I just had 14mm in the rear and 7mm in the front installed. No real difference in feel but the look is great. I didn't think it would be that noticeable but it is. I'll try to post pics when I get a chance. The only problem is that I need new wheel locks because you need to replace the lugs when adding spacers. I'm afraid I will have to get two different sets for the two depths.
Pics’ would be great!
Did your wheels have same offset as stock turbo twists? Any problems with the tires rubbing the inside of the fenders with the 14mm spacers (or 7’s for that matter?
Thanks, PK
