Old 10-16-2007, 07:09 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
It is a straight swap. Pop out your halogens, pop in the Litronics, and it will work fine. However, if you want to have the additional feature of having the litronics tilt up a few degrees to help the high beams when they are turned on, you will have to also install the wiring harness. If you don't install the wiring harness, you will still have high beams when you turn them on, but the litronic low beams will not swivel up a few degrees to help add more light to the high beams.
