Originally Posted by Back2DTM
Is this a common problem? It is funny my gf's car's honk stopped working, too.
So you're not horny and your gf isn't horny either... I'm sorry.
Seriously though, yeah horns can stop working for several reasons. First I would check the fuse. Then I'd check the horn relay and test it. Then I'd try applying power directly to the horns and see if they work. If all of that fails, then you probably have a broken clock spring inside the steering wheel. These do tend to fail over time and is probably the most likely problem if the fuse is still good.
Kirk
