These sway bars... the HR and GT3 front have adjustability built in... for one you will need new droplinks so that you can adjust to the bar's various holes. Also the stock droplinks are very fragile and an upgraded sway bar will put more stress on the droplinks than the OEM links were made to handle... I and many other owners buy from Tarrett Engineering. TRG also sells some, as does acency power. I would recommend the Tarrett pieces. And yes I mean all four corners... F & R. The rear HR will cause some oversteer...
