Yes this sound like a bad altenator. Are you sure the battery polarity was connected correctly? I've seen it before where the battery was hooked up wrong and it damaged the alternator.
The alternator is easy to remove but I would take it in to have the regulator replaced. Also check all the fuses and replace any that are damaged.
