Old 10-01-2007, 12:44 PM   #6
fatmike
Update:
Well my glorious September has turned a bit cloudy so far here in October.
The Boxster did marvelously for a while, but its started to run a bit "ragged" over the past week. No doubt I've driven it more in the last month then at any other point in its life. At first I thought I was imagining it, but I am not. The CEL hasn't come on, but I'm sure it will if I keep driving it (which I'm not).
I suspect an AOS issue. I occasionaly have a little more smoke at start-up than anyone could consider "normal". Also at start up, the idle is a bit irratic. While driving the exhaust isn't quite right. IF you lift your foot on the throttle, there is an exhaust "burble" as you de-accelerate. This is likely a throttle body issue -- hopefully caused by a failed AOS. I say hopefully, because I've been able to read on this forum about a failed AOS and the symptoms to know that its a relatively easy fix.
I was hoping to be proactive and stay ahead of these things -- oh, well.
I've made an appointment to bring it into a dealership for a check-up & we'll see what's up.
fatmike is offline   Reply With Quote
