Originally Posted by frederic
I just had a good tranny maintenance on my Boxster but still have a shifting problem. The automatic transmission fluid, filter and gasket were change and I still got this weird problem during normal driving condition (2500 rpm). Sometime during shifting from the 4 to the 5th gear only, the engine rev up without engaging the 5th gear and then it finally engage hard... really hard... I don't have this kind of problem when I drove at high rpm's or on any other gear change, only during smooth driving... Anybody had tiptronic problems like these... Where should I look for first...Torque converter, tranny, electronic control...? BTW I got an engine vibration always at 2000rpm at any speed on any gear... Need some advice.
Ok, so you have a 10-year old Tiptronic tranny that you said just had a "good tranny" maintenance, but still shifts poorly. I would assume this was done at a reputable Porsche or German car care center? I am confused at how the tranny shop missed your obvious transmission failure problem. I fear that due to my extensive racing experience with other makes and trannys, you may be in for a costly repair or replacement. I have yet to see alot of "cheap" fixes to major shifting/tranny issues. Then you said you have an engine vibration? I would have to say exhaust, motor mounts, drive train etc....have you had this checked out by a Porsche technician?
all the best...
