DJ,
Standard tire diameter on your car is 25" front and rear. You now have 25" fronts and 26.5" rears. The rears may never fit right, will effectively raise your final gear ratio 6%, will raise your car up 3/4", and it may cause issues with you ABS. Are you sure you want those tires on the rear?? 265/35/18 or 285/30/18 would be a better fit. IMHO
