Old 09-17-2007, 07:28 AM   #1
OldBlevins
Kdub, the owners manual says the alarm system is switched on with either the key or the remote control. Best way to check it is to look at your LED on the front dash. If it flashes, the alarm is active. If after 10 seconds it emits double-flashes, then one of your contacts is not closed (usually the console between the seats). If it doesn't flash at all, it's not active.
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
OldBlevins is offline   Reply With Quote
