Old 09-15-2007, 03:43 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
It's actually quite simple. All you need to do is lift the door bin lid to the up position, and then you'll see two hinges (front and rear). Use a paper clip or hole punch to push out the plastic pin in the hinges, and then pull them out with needle nosed pliers. The rear hinge also has a spring which you can carefully remove before releasing the lid covers. That's it. Good luck.
