Old 09-14-2007, 08:48 AM   #22
simbob
Back to the drains
I found the two additional drain lines in the rear, shown as "2" on the diagram.
They're at the front extreme of the outer vertical edge of the rear deck cover channel. When the top is in the service position, you can run your finger along that edge of the channel and find them just behind the doors.
So there are four drain lines in the rear, not two.
I still haven't found all of the front drain lines shown on the diagram, but I'll take the front end apart and take the battery out to search for them this weekend -- unless one of you can give me some advice from your experience about where I will find all of the locations shown on the diagram.
Thanks.
simbob is offline   Reply With Quote
