Thread: Wont start
Old 09-09-2007, 08:37 PM   #4
P-51 Mustang
Its was easy, you can just take a wire and run it from the battery to the pump and ground it, it will turn the pump on for a minute, just long enough to get about 40 psi in the line then you can plug up the original power harness to it and all should be fine.
P-51 Mustang is offline   Reply With Quote
