Thread: 45k mi Service
Old 09-04-2007, 03:36 PM   #25
Sammy
Originally Posted by NickCats
Alright, I think I priced everything out :
Brakes
Front Pads 986.351.939.15 $122.71 pair
Front Rotors 986.351.401.05 $131.82 each
Total : $386.35 ( save $463 ! )
( prices from ****************************************************.com )
Brake flush - $15.00 - 1 liter ATE 9001 Super Blue Racing Brake Fluid
Save $125 ! ( price from northstarmotorsports.com )
Tires
Front - Nexen N3000 - 225/40ZR18 - $84.00 each
Rear - Nexen N3000 - 265/35ZR18 - $114.00 each
Total $396.00
( I have these on my car now and I am very pleased with wear / performance )
Other than cost for an alignment, did I forget anything ?
Thanks,
Nick
Thank you for the congrats!
You might want to count on 2 liters of brake fluid to do the clutch fluid at the same time and make sure you have plenty. You could do it with 1 liter, but I have found that 2 liters gives it a real good flush without concern of running out. The last thing you want is to come up short in the end.
As long as your steering wheel is tracking straight you might give your local Firestone a call as their alignments are quite a bit cheaper. My local Firestone has some very nice alignment equipment. They can't reset the steering wheel as evidently you need to hook it up to some special device to do this.
For your front brakes it would be worth measuring the rotor width as you may just need them turned. I don't believe you have cross drilled rotors?
Sammy is offline   Reply With Quote
