Just two more photos to try to clarify things here. You should be able to see the Ernie Bar mounted up high, kind of behind the anti-sway bar. The eye bolt portion of the smaller, lower bars are mounted just below the Ernie Bar at the same mounting bolts that are used for the Ernie Bar.
BTW, these eye bolts make it MUCH easier to mount the bars as there is some adjustment then allowed. I know Franco didn't have much trouble with making his Ernie Bar, but I followed my classic rule of measure three times and still cut (or in this case, drill the holes) WRONG. It was a bit of a PITA to make this stuff. The Mantis Sport bar should be a LOT easier to mount, or I guess you could just drill the damn holes in the right spot to start with.... Either way, a big thanks to Mantis and especially insite for bringing this mod to everyone's attention!
Kirk B.
