Old 09-01-2007, 04:44 PM   #6
boxstershorts
Hi ToolPants!
No, I have a 2003 S. Can't remember refering to a 2001 (might have been while I was still shopping for a car). That link you gave me shows what seems to be the same speedo motor as in my speedo. As I mentionned I took apart the speedo down to this point which is relatively easy (with care and proper grounding). But I couldn't open the motor in situe and didn't want to unsolder the motor from the board before knowing what to do after that. Note: Before: the needle had some resistance to rotation during adjustment. After: no resistance at all but the hard stops at each end of travel.
Does a base model cluster motor have the same travel as an S model (I mean, do the indicated speeds have the same intervals?) I'm trying to find out if I can swap a base model boxster cluster speedo motor into mine.
Sorry to throw so much at you (you're a lifeline!) but what is your take on my idle RPM problem? (I mean aside that I'm an idiot for touching connectors in the first place...but what better way to learn)
JP
boxstershorts is offline   Reply With Quote
