Howdy Neighbour,
Nice to meet you.
Rear fog light: Only one light is intended to be on: I'll have another read through the manual and check it out. I found it strange that they would put a socket and wire on the right side if there is no intention to use it. I'll check it out. I also read somewhere that some drivers use the rear fogs to scare off tailgaters. But that's plausible because there was no light in the socket.
CE light: Turning off the light is one issue. The other is that the engine is revving way to high. I'm giving it a few hours to cool down and see if anything changes. When I let it sit 30 minutes or so, it was a more stable idle speed (at first it was very erratic idling).
JP
