If you would rather repair the tire it should be fine. I was concerned when I had a nail hole (just before a track day). I consulted the tire manufacturer and this was their response:
"If all of the following below was completed by a competent tire professional, then the repair should be fine for the life of the tread.
The tire was thoroughly inspected prior to the repair, with the tire showing no signs of run low or run flat.
The puncture was ¼” diameter or smaller and in or near the center area of the tread.
The tire was properly repaired using a plug patch combination
Please note that the Tire should now be de-rated by one speed rating. So if you have a “W” (168 mph) speed rated tire- it should now be considered a “V” (149 mph). This maximum would be for the vehicle, even if the other three tires had the W rating or higher."
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
