Old 08-27-2007, 07:52 PM   #1
KevinH1990
KevinH1990's Avatar
I've had some issues with my 2000, but nothing fatal. I had about $1000 of unplanned expenses in my first year of ownership including the Mass Air Flow sensor and a fuel system vent tube.
You can make Boxster ownership more practical with some planning.
1. Find a good independent Porsche mechanic. I know you said you thought that the dealer was the only option in your area, but with some research you may discover another option.
2. Plan for tire replacement. Learn about the available options and buy over the Internet. This can save you several hundred dollars on each tire change. The same advice applies to the battery.
3. Learn to do some maintenance yourself and buy the parts on line. Changing the oil is not that difficult. You should also be able to handle the cabin filter and the air filter.
