Well, if you look at what I said earlier, the best of both worlds, Cross-drilled & Slotted would be the best as long as the surfaace area is larger than the stock application rottors. In which most cases, just about any aftermarket performance rottor that you buy to replace the stock ones are usually bigger. Never seen an aftermarket rottor that was the exact same size as the stock one, like someone said earier that would defete the purpose of having them cross-drilled or slotted. :ah:
