There is foam insulation next to the tank. My insulation was soaked from the coolant leak. I pulled it away and let it dry before I put the floor and carpet back in. You can see the foam in the left side of the picture after I pulled it away from the tank.
There was a slight smell after the tank replacement, but it went away. No clue about your smell. Maybe you should just give it some time.
