Originally Posted by J-RAD
There are no cross-drilled OEM rotors for the base model.
In addition, going to a cross-drilled rotor with the OEM base design means that you are reducing the swept surface of the rotor and likely to increase your braking distances (ie. decrease effectiveness).
On the 986 or the 987? The 987 I looked at was a base w/cross drill rotors.
