Old 08-22-2007, 09:08 AM   #11
chaudanova
Originally Posted by tkn
Oh well, I suppose that would be the problem, as I am sure the I-6 of the 2JZ is quite a bit longer than that (hmmm, although I would be willing to give up the tiny rear trunk...) Perhaps a V6 engine might fit better depending on the configuration, something that is a bit more durable than the stock flat 6.
aside from the engine length and configuration, remember you gotta factor in the tranny too!
go for a x51 3.8L from a 997S and build that badboy up
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
