Thread: CryO2 products
Old 08-20-2007, 12:48 PM   #4
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by NickCats
Blink,
How is the existing Boxster intake system "cold air" ? I thought the two vents on the Boxster suck air into the engine bay and push air out ? Isn't the air filter still pulling air from the engine bay ? If it's 100 degrees out, wouldn't the engine be sucking in warm air ?
Nick
Nick,
When you go home tonight look through the driver side intake vent. You should be able to see the air intake system,it's a square shaped box thing-a-bob that should have this tube leading from it(you won't have the tube if you've desnorkeled). Despite the system stills being in the engine compartment it's considered a 'cold air' design because it's a closed off from the engine heat all the way to the throttle body.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
