Old 08-18-2007, 01:33 AM   #3
aussieboxy
Last Step
5. Replace the trottle body with the 4 hex bolts. Careful not to overtorque as they are into a metal sleve in plastic. Just hand tight then nip them up.
6. Replace intake tube. It can be a little difficult to get the end back on the throttle body so I used just a little WD 40 or CRC on the inside lip to help it slip back on.
7. Tighten both end clamps of intake tube & start her up.
8. Replace engine cover & return hood to normal position & your done.
Quite easy to do and should only take you about an hour or so from do to wow.
If you have any questions PM me.
Good luck.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
