Originally Posted by blinkwatt
The stopping distance between the base & S brakes is so small your better off putting money elsewhere,perhaps better tires.
Blink, you're probably doing the braking test wrong if you think that's the case. The test is as follows: start at 20 mph, accelerate to 130 at full throttle, then threshold brake down to 20 again. Repeat 20-30 times, and only on the last one measure the distance from 130 down to zero.
It's not a matter of doing it once, but how many time you can do it where the big brakes give you the advantage.
Eric
