Old 08-13-2007, 12:24 PM   #8
clb0099
*update* Got Response From Durametric
The following was a letter I got from the company
HI Chris,
The fault codes you see in the alarm control unit are very
common. Since none of the fault are currently present then none of these
faults are currently at fault.
As for the Air conditioning fault I would recommend that you attempt to
clear the fault then perform a system check, and see if the fault
returns.
If you have access to a factory manual the diagnostic section will show
the troubleshooting and repair information for each of these fault
codes.
Please let me know if you have any more questions.
Best Regards,
clb0099 is offline   Reply With Quote
